Toshiba 32ZP48 buzz
Discussion in 'Televisions' started by Rob149, Feb 3, 2005.
  1. Rob149
    Rob149
    My 4 month old 32ZP48 develops an intermittent buzz (not through the speakers) when it has been on for an hour or two. The buzz changes in volume and intensity when the picture scene changes. The brighter the scene, the louder the buzz! Could this be a degaussing problem?
    It's not particularly loud, but annoying nontheless.
  2. scottiefraser
    scottiefraser
    Sep 20, 2004
    512
    46
    +172
    Had exactly the same problem with mine although the problem was only when the TV was set to Progressive mode. I bet it buzes badly when you get graphics up on the screen too?? e.g. Sky Banner??.
    Spoke to Toshiba direct and then spoke to retailer who got it changed via Toshiba. I would try and do the same if I were you because once you know its there, it will annoy you more and more!
