Toshiba 32ZP38/32ZP38B
Discussion in 'General TV Discussions Forum' started by bubomb, Jun 30, 2004.
  1. bubomb
    bubomb
    Hello everybody. I have decided to buy the Toshiba 32ZP38/32ZP38B, but can anybody tell me the difference between the 2 model numbers. I can get the 32ZP38B for £800 but I am worried that it's not as good as the 32ZP38. Can anybody help. Thanks in advance.
  2. chrisbin
    chrisbin
    Mar 22, 2004
    287
    S.Wales
    +5
    I'm under the impression that the 38B is the latest version.......
    Can you tell me where you can get it for £800, cos the best I've found so far is £850....... :confused: :confused:
    THanks :thumbsup:
  3. bubomb
    bubomb
    Hello. There is a large electrical store in Glasgow called 'Whytes', and that is where I bought it today for £800. The cheapest online I have seen is also £850 plus delivery. The 'B' stands for black trim which is the model I wanted. The 2 models are identical apart from the trim colour.
