Toshiba 32ZP18P yes again!!!
Discussion in 'General TV Discussions Forum' started by sc00by, Sep 21, 2001.
  1. sc00by
    sc00by
    Folks,<br /> Does everyone with this set have a problem with it?<br />I ordered one before reading this newsgroup (smart huh) from JL and now I'm a bit apprehensive that it'll have a problem specifically:
    Dark vertical bands<br />Contrast bloom<br />Transformer hum<br />Geometry problems
    I'm not too bothered about the stuff that can be fixed ie geometry but the dark bands are a big concern.
    Ta
    Sc00b
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    I only have the picture washing out on brightly lit sets and sunlit scenes. Particularily bad on analogue and only slight on digital, new set coming next wek. None of the other problems at all, just hope the replacement is ok.
  3. rudgej
    rudgej
    Sep 18, 2001
    7
    Edinburgh
    I was a bit concerned too when I came across this forum and all the posts with problems. Fortunately for me though, my 32ZP18P has had none at all, and I'm really pleased with it. <img src="biggrin.gif" border="0">
  4. sc00by
    sc00by
    John,<br /> Can I ask when you got your TV. I wonder if there's a bad batch out there.<br />Ken can you let us know what your next TV is like?<br />I've got to pick mine up next week and apparantly it was the last one in the warehouse so I'm hoping it's not the last of a bad bunch.
  5. Doubledoom
    Doubledoom
    I got mine about a month ago and it is not suffering any of the problems mentioned elsewhere. I do have the dynamic contrast turned off (via pic setting 3) which i would recommend to everbody with this set or the 36" version.
  6. rudgej
    rudgej
    Sep 18, 2001
    7
    Edinburgh
    Dave, I got mine last monday (6 days ago <img src="smile.gif" border="0"> ). It took me to about thursday to connect it the way I wanted (mainly because I couldn't be bothered tacking cabling around the room for the rear speakers).
  7. quango
    quango
    i was gonna go for this set because of its fantastic looks and DD sound etc. however, much as i tried i couldnt get a decent picture. The picture looked processed and grainy (mainly broadcast pictures). My 12 year old sony has better pictures!<br />In the end I opted for the sony FQ75...a picture with which ive yet to find a fault.
  8. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    Replacement tv came today, and installed whilst I was at work. (Got all the speakers in the wrong places and couldn't set up the digital soungd input!)<br />Anyway, now perfectly watchable on tuner, although still slightly overbright on whites and sunlit areas. Grass is now green though!! Certainly as good as the video tuner, which I was having to use before to get any sort of picture from ITV.<br />Superb picture on sky, vibrant colour, my old set must have been way out on sky as well because it never looked this good. I cant see any geometry errors, top, bottom and sides all appear straight from normal viewing distance.<br />Funnnily the teletext also seems to be working faster as well, so that must also have been faulty on the store of pages.
  9. plb
    plb
    Pleased to hear that your replacement set is OK.<br />I guess you will have to adjust your picture settings now from the settings you had on your washed out set.<br />Paul<br /> <img src="smile.gif" border="0"> <img src="smile.gif" border="0">
  10. sc00by
    sc00by
    Just got my 32zp18p and it's fantastic out of the box. I can see a small amount of bloom on very white object like sun shining on a white shirt against a darkish background but I think I've been looking for faults.<br />The geometry, colours and sound are all excellent.
    Thanks to all for your advice.
    Dave
  11. Doubledoom
    Doubledoom
    Does the blooming occur with Dynamic contrast on and off or just when it's on?
    I have found that the blooming does not occur when it's off.
  12. sc00by
    sc00by
    Not sure DD, I'm still playing with my new toy. I'll post when I've tested a bit more.
    Dave
  13. se_warner
    se_warner
    Dec 6, 2000
    65
    Sandhurst, Berks,UK
    Have just received my 32" set and have what I consider 2 problems. One is to do with purity in thatI get a blue tint on the lhs and other paches elsewhere. Using Video Essentials it looks really messy on the white and red screens.
    Second problems is that the picture via the aerial looks very grainy. This set as a replacement for a Panny pg30 which had the shaddowy problems. However, the picture looked great via the aerial. Now if I freeze the picture you can see it very grainy.
    Are these the same problems that other people have seen? If so what is the fix?
    Thanks<br />Steve
  14. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    Cant help with the tint, but if you select the menu for picture adjustment, then wait for a suitable picture that shows the problem you are having, you can use the freeze button to hold that picture whilst you try the adjustments. I set the sharpness to -45 and most of the grainyness disapears.<br />If you have variable tints even from a good source, it could be caused by speakers too close, or you may have a duff set, which needs adjusting or replacing. I am on my third set, and I think it is finalyy a good one.<br />If anyone finds out how to alter the too bright whites though can they let us know please, as I still have it slightly through the analogue tuner principally.
