Toshiba 32ZP18
Discussion in 'General TV Discussions Forum' started by mustang, Apr 18, 2002.
  1. mustang
    mustang
    Does anyone know if you can download the manual for the 32ZP18 anywhere.
    Thanx.
    mustang.
  2. johnski
    johnski
  3. mustang
    mustang
    Cheers m8! :)
    mustang.
  4. mustang
    mustang
    Are any Toshiba 32ZP18 owners using the stand it came with or are you using a dedicated AV stand?.
    The reason i ask is that i have the Soundstyle AV stand and was wondering whether the Toshiba would be okay on this.
    Thanx! :)
    mustang.
  5. mortimar
    mortimar
    Jan 14, 2002
    45
    Northampton
    With my Tosh 32zp I use a a dedicated TV/AV stand . The one it came with has never came out of the box. I can't think of any reason why Toshiba would be bothered if you don't use there's
  6. mustang
    mustang
    mortimar,
    I wasn't sure as the pictures i've seen make it look like the speakers are part of the stand :confused:
    Cheers!
    mustang.
  7. mortimar
    mortimar
    Jan 14, 2002
    45
    Northampton
    the speakers aren't part of the stand. THe stand must line up with the speakers . THe bottom of the TV has a little section missing each side next to the speakers in which the TV stand must slot into.
