Toshiba 32ZP18
Discussion in 'General TV Discussions Forum' started by shins28, Mar 13, 2002.
  1. shins28
    shins28
    Hello all,
    I have just purchased a new TV [Tosh 32ZP18] but in my rush I neglegted to ask the sales guy if you can split the TV from its stand. I've looked at the pictures and it looks like the front AV inputs and speakers are part of the stand.
    I would prefer to mount the set on top of a piece of furniture that was bought just for this purpose, have I made a boob?
    Can anyone enlighten me please?
    TIA...........Tony
  2. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    With the 36" you can stand the set on it's own, but it would look a bit odd. The inputs and the speakers are not part of the stand, but the stand front comes higher than the shelf at the sides giving the look the the two are linked. If you stand the TV on it's own then you will have a gap either side that will look a bit odd. Also what ever you put it on make sure it can take the weight, these thing are VERY heavy.
  3. shins28
    shins28
    Thanks, I'll just have to hope it doesn't look too odd or else my wife will kill me........... again!
    Tony
  4. escossie
    escossie
    My 32zp18 is on a corner unit & it looks fine.Just make sure what ever its on is good & strong.
    Graham
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +17
    Don't forget that the tv is strapped at the rear to it's proper stand with a large slug of lead at the back of the stand to ensure reasonable stability. Sitting on another stand without this strapping and counterweight it could conceivable be toppled forward onto a child (or even an adult) etc with fatal results, as it would be front heavy.
  6. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    That's the very reason Loewe make their stands so the TV tilts slightly backwards. The Germans are very safety conscious in this respect. There have actually been a few incidents where the TV did fall on a small child resulting in death. There was one in the UK not that long ago.
  7. Doubledoom
    Doubledoom
    And it is an extremely heavy television set. It seems to weigh half as much again as my previous 32" widescreen set.
    Make sure the stand/cabinet can take that weight.
  8. shins28
    shins28
    Thanks for all the input, I may have to revise my furniture arrangements.
    Tony
  9. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    Where should the strap be? There don't remember there being one with my set.:(
  10. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +17
    Its a metal clip which screws to the rear of the stand, clipping over a lip on the back of the set
