Quantcast
Toshiba 32ZD26P Resonating problem...
Nimmo
Hi, first of all I should thank this forum, because it was thanks to you that I got my "tearing" prog scan effect sorted out so fast. So cheers!
But I'm noticing a funny resonating effect, on the right edge of the screen. It's not a huge problem but it is annoying, and curiously it only happens on EXT-4 (the component one). Has anyone else had a problem like this? Any way of fixing it?
Cheers again,
-Nimmo
