Toshiba 32ZD09B hidden setup menu
Discussion in 'General TV Discussions Forum' started by BIONIC MAN, Jun 29, 2002.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    I own the Toshiba 32ZD09B ,
    Can you advise or try and help me find the hidden setup menu
    which i know must be there somewhere ? ? .
    My Tosh just needs a little help with it's face etc ,
    So if anyone know were to find please reply ,
    :D
  2. Doubledoom
    Doubledoom
    Same as all the other Toshiba televisions.
    Take a look on google under uk.media.home-cinema or on these forums. I suggest a search on Toshiba service menu would give many results.
    Be wary that many of the screen modes share settings on the service menu and that playing with some of the settings on the designer menu can lose your picture. There is no reset to return to factory defaults either so write everthing down.
