Toshiba 32Z13B - Any Good
Discussion in 'General TV Discussions Forum' started by Stephen Kinsey, Aug 5, 2002.
  1. Stephen Kinsey
    Stephen Kinsey
    I'm looking at this TV on unbeatable.co.uk and I'm wondering if anyone has any experience of it. If not can anyone recommend a 32" widescreen alternative within the £800 price bracket.
    Ideally it would be flat screen, 3 scart sockets (2 RGB), 100 Hz would be nice but not essential. I do realise that I'm probably asking a lot for 800 notes.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    suggest that you stay away from this one Stephen, do a search for Z17B (which is the same TV but with Pro-Logic) and you'll find that you'll be lucky to get a decent one. I had a 32Z17B and had to get rid of it after no end of problems. Many people say good things about the Panasonic PL1, the Sony LS range is often recommended too. Have a look at pricerunner for TVs in your price bracket, come back with a shortlist and I'm sure the guys here will be able to help you steer clear of complete disasters ;) Good luck!
