Toshiba 32WLT58 problems - please help!
Discussion in 'LCD & LED LCD TVs Forum' started by matt_knight1984, Mar 25, 2006.
Tags:
  1. matt_knight1984
    matt_knight1984
    Mar 13, 2006
    3
    Hi guys,
    Hope you can help. I have searched, and found loads of threads about this TV but cant find the answer Im after!
    I have had the TV for a week now, and its great - however there is one thing that bothers me:
    I have Telewest cable, and when changing channel the TV will switch from 'wide' to '4:3' automatically. I can switch it back and it stays like that until I change the channel again.
    Its not a major problem, I dont regularly sit flicking through channels!
    Does anyone else have this problem?
    Thanks in advance,
    Matt K
  2. gaz2785
    gaz2785
    Mar 2, 2006
    820
    28
    +24
    Does it help if you turn "Auto Format" off?
    I think auto format is to do with switching to widescreen when you play DVDs, but I'm sure I had a similar problem with freeview, which I got round by turning Auto Format off.
