Toshiba 32WL66E &ATI Display card with VGA input
K
kenfong_r
Dear All,
My Nivdia 6600GT was connected with 32WL66E by VGA input at 1360*768 and 85Hz.
It is perfect to display all screens on 32WL66E. Then my another ATI X700 was connected with 32WL66E by VGA input at 1360*760 and 85Hz. However, it can't display all screen . Does anyone try to connect your ATI display with 32WL66E ?
Can you tell me your setting and driver version ?
Thank you:clap: :clap: :clap:
Andy98765
kenfong_r said:
Dear All,
First off set your ATI to 1360x768 @ 60Hz (default for screen) then in the menu of the TV you can resize, or use the resize in the ATI Catalyst software. Latest driver from ATI is https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=640
