Toshiba 32wl56
Discussion in 'LCD & LED LCD TVs Forum' started by JayHarkin, Aug 28, 2005.
Tags:
  1. JayHarkin
    JayHarkin
    Hi Guys
    I am going to be buying the 27wl56 in the next couple of days. I will be using it primarily with the xbox360 when it is realeased to recieve HD pictures. However My problem concerns the lack of component connection here is my questions. From reading the forums if I buy a Component to Vga converter I should be able to recieve HD pictures via component. However an optional VGA cable for the Xbox 360 will be on sell at launch, would I recieve HD pictures if I used a vga cable with the 360 on the Tosh?. Also why are the prices so good on this tv? Any info much appreciated.
    Regards Jason
  2. peahead
    peahead
    Dec 14, 2002
    2,998
    St.helens
    +384
    Yes you can use the xbox360 vga cable with the tosh as for price competition i suspect.
