Toshiba 32WL56 - Widescreen PC Display
Discussion in 'LCD & LED LCD TVs' started by hopfume, Jun 12, 2005.
  1. hopfume
    hopfume
    Hi all,
    I'm a couple of weeks into owning a Toshiba 32WL56 and I'm really enjoying my new toy except for one thing. I've got PC hooked up to it using the VGA d-sub cable (using the HDMI connection for my DVD player) and its working fine, but I've got an issue regarding using it as a widescreen display.
    When I hit changeover to widescreen mode, the screen just gets stretched out. When I try to change the settings on my PC (which, BTW, has a Radeon 9600 graphics card) I can't find one that fits the monitor size. I really want to use my PC to play films but I find the image distortion the stretched screen causes to be distracting.
    Any ideas??????
    Anthony
  2. minty_fresh
    minty_fresh
    you may want to check that your card is not set to stretch the image to fit the display. i have a similar problem using my widescreen notebook with a normal TV. in my case the problem was solved by selecting resolution with a similar aspect ratio to the TV.
    hope that helps mate.
