Toshiba 32wl56 or Samsung LE3241BDX
Discussion in 'LCD & LED LCD TVs' started by armando1065, Sep 22, 2005.
  1. armando1065
    armando1065
    Sep 16, 2005
    54
    I am looking for a 32 inch LCD tv for under 1 K - i have read most of the threads (mostly :lease: excellent) about this and a bit of a novice so its like quicksand, the more i struggle the deeper i go under and more confused.
    I think ive decided on the Toshiba 32WL56 but am just concerned (if thats the right word) about it not having progressive scan and component video inputs- i will just be hooking a dvd player/recorder (yet to buy one) and a Sky box to it. i wont be using it for PC games.
    Is component video the best connection for quality (i told you i was a novice?)
    Any final advice before i take the plunge in the next few days ?
  2. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,046
    oop north.
    +2,590
    most people seem to be plumping for the Samsung...it is a very good TV, I just forked out on the 26" model without the Freeview.. As for the connections, I'm not the one to help unfortunately. BTW, the Samsung with the BDX ending means that it includes Freeview, as you have Sky there will be no need for this so if you look for the Plain old "D" ending you will find it a bit cheaper.
    Use something like www.pricerunner.co.uk to do a direct comparison of the two you like.
  3. MADMAND
    MADMAND
    Aug 4, 2005
    343
    +8
    Best to Worse
    Hdmi>dvi>component>scart-rgb>svideo>composite.
  4. armando1065
    armando1065
    Sep 16, 2005
    54
    Thanks for the quick best to worse list of connections - so does that mean a lack of component on the Toshiba wl56 is a serious drawback - ie. Will it be noticeable in terms of quality of picture ?
  5. MADMAND
    MADMAND
    Aug 4, 2005
    343
    +8
    The 56 range are able to take component. You need to buy a yuv to vga lead http://www.beststuff.co.uk/specialist_rgb_leads.htm ixos make a yuv to vga it is available through the toshiba site.
    I have the 27WL56 it is very good, but it does buzz which is audible if you put it on mute.There is quite a difference between yuv progressive and scart-rgb.
  6. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    978
    Coventry
    +33
    Samsung 32. beautifullll. Get one!!!! I have no regrets....
  7. HHGTTG
    HHGTTG
    Aug 1, 2005
    854
    South London
    +63
    How do you find not having an adjustable backlight control affects your viewing?
    As a result, are you able to obtain a restful picture in more subdued night time lighting without the picture being possibly too bright and overpowering?
  8. armando1065
    armando1065
    Sep 16, 2005
    54
    I was all ready to go for teh Samsung this weekend and then i read the thread rasied today about the picture quality being very very poor for this LCD - no i am confused - At the moment ive got a DM TECH (cheapish with an inbuilt dvdv player) that the kids and the pciture quality seems okay to me - unless you stand with your nose against the screen.
  9. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,065
    Essex
    +74
    wait a week and have a look at the new toshiba 32WLT58 it has component and 2 hdmi connections it is all looking good i have already preordered mine should be here next tuesday.
    they are already in short supply due to the demand for this lcd
    hope this helps
  10. armando1065
    armando1065
    Sep 16, 2005
    54
    Thanks for that - what price is the new Toshiba WL58 ?
  11. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,065
    Essex
    +74
