Toshiba 32WL56 lcd wall mount?
Discussion in 'Home Cinema Buying & Building' started by willmoore, Jul 18, 2005.
  1. willmoore
    willmoore
    I am looking at getting a toshiba 32wl56 lcd tv but would need to wall mount it to get it out of the way of little hands.
    I have tried toshiba customer support, but I think hell might freeze over before I get a reply judging by previous experience...
    Anybody got this, or another toshiba 32"+ panel, wall mounted? :lease:
  2. abridge
    abridge
    Hi, I just bought a 37wl56 and have wall mounted that - used a universal mount from tvandvideodirect £99, also bought my telly from there and got excellent service. The mount is very strong and very good value i think. Hope that helps.
    A
  3. willmoore
    willmoore
    abridge, thanks for the help.
    I have had a look at tvandvideodirect site, is that the vivanco wms3260ps, the B-Tech BT8000 + BT8500 or the B-Tech BT8000 + BT8600 (all £99) you got? Does it have any adjustment e.g. tilt?
    These things cost and arm and leg, so although I would not have agreed with you a few weeks ago, £99 does seem reasonable!
  4. abridge
    abridge
    willmoore , drop them an email saying you have the 32wl56 and ask which set of wall mounts are applicable , they are very quick at responding :) Mine is one of the B-Tech pairs but cant remember which off hand. They are very strong brackets and if you look on the B-tech site are classified under the professional brand.
  5. willmoore
    willmoore
    abridge, thanks. I did drop them and email and quickly got the reply that it is the BT8000 + BT8500 - just in case anybody else is interested!
  6. bluetractor
    bluetractor
    also used tvandvideodirect recently - spot on prices and service - would recommend.
