Toshiba 32wl56 full spec inside
Discussion in 'LCD & LED LCD TVs Forum' started by brock_landers, Apr 18, 2005.
Tags:
  1. brock_landers
    brock_landers
    May 2, 2001
    100
    lancashire
    There seems to be a lot of controversy over the spec of this new Toshiba model. Here is the official specification:-
    Resolution – WXGA 1280 x 720
    Active Vision LCD Picture Processing
    Real Digital Picture Processing
    Brightness – 500cd/m2
    Contrast – 800:1
    Viewing Angle – 170 degrees (Vertical & Horizontally)
    HDMI x 1
    SCART x 2
    Composite x 1
    Audio Output – SRS WOW 20W
    Floor stand will be an optional extra
    Interestingly, no component input.........
    Brock.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Without a component input they can't claim it to be HD ready - seems a strange move by Toshiba. :suicide:
    Steve
  3. nemo
    nemo
    Nov 19, 2003
    406
    28
    +25
    And the resolution is lower than the 32WL48's 1366 x 768
  4. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    Where did you get the specs for this??
    It seems very very strange for Toshiba not to include component inputs...just about every one of their home cinema TV's have had component inputs for the past 5 years.
  5. Howardlee
    Howardlee
    I've been told by TVandVideo direct there is no component on this model. I have seen the brochure for the German model(it has the same model number). It has a res of 1366 X 768, 2 scarts(1RGB), no component.
  6. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    This must be their cheap and cheerful model then.....although not bad value i guess with HDMI!!
  7. Zigster
    Zigster
    Jan 5, 2005
    108
    16
    I'm confused: I thought HDTV is going to be piped through HDMI or DVI-D not component.
  8. DanH
    DanH
    Feb 16, 2005
    604
    +56
    Your technically correct, and Toshiba can claim it is HD ready, but it cant carry the "HDTV Ready" logo, as the rules for carrying this logo say the panel must accept 720p/1080i 50/60hz through both component connections and HDMI/DVI with HDCP.
  9. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  10. Zigster
    Zigster
    Jan 5, 2005
    108
    16
    Thanks. Very useful.
    You're right - seems very odd that Toshiba would miss out the component connection - the 32WL56 is effectively HDTV ready, they're just not allowed to label it as such. Still :confused: , just for different reasons now!
    PS. Couldn't access it through the link you posted - not sure why. I found it by going to their website and searching the press releases for the 20 Jan 2005 "HD Ready" document.
  11. andrewf
    andrewf
    Apr 26, 2005
    1,031
    48
    +28
  12. Howardlee
    Howardlee
    If you click on Technische Datan, the 32wl56 only has 2 av inputs, no mention of component. Click on 48 it says 3 av inputs and component.
  13. tosh hunter
    tosh hunter
    what is component used for again...i read it before but have forgotten with all the dvi and hdmi input debate
  14. andrewf
    andrewf
    Apr 26, 2005
    1,031
    48
    +28
    its all a bit confusing!!
    as you say the Technische Datan tab says only 2 AV in, though the anschlusse tab lists three. The Datan tab does include Prog scan under 'Bild' though and I thought this only came with component.
