sprint blue
- Joined
- May 20, 2005
- Messages
- 100
- Reaction score
- 1
- Points
- 30
I get the above items tomorrow, but have a copy of the RDSX34 owners manual.
The manual suggests that the TV and DVD are connected by use of a scart cable.
Then a couple of pages later on it goes onto say that if the TV has component video inputs then you can obtain pictures in better quality.
I was under the impression, probably mistaken, that scart to scart was the connection of choice for superior picture quality, but now I am well and truly confused.
THe LCD has the following connections :
Fixed audio output, HDMI, Headphone, PC compatible, Scart x 2, Composite video, s-video and RGB x 2.
The DVD has the following connections :
component video, composite video, optical audio, Scart (RGB) x 2, s-video, dv input, co-axial audio, analogue 2 channel audio.
Any advice would be appreciated.
