Toshiba 32WL56, 32WL56P difference?
Discussion in 'LCD & LED LCD TVs Forum' started by Kowkow, Oct 20, 2005.
Tags:
  1. Kowkow
    Kowkow
    Hello, just wondering if there's a difference between Toshiba's 32WL56 and the 32WL56P version, and also if the 'buzzing' which comes from the unit (apparently), is really much of an issue.
    Any pros,cons/remarks about this model would be much appreciated...
    Thanks in advance.
  2. nick501
    nick501
    May 6, 2005
    7,217
    Walsall, West Midlands
    +782
    there is no difference. as for the buzzing.....very slight on mine (27") not an issue for me really.
    there is already alot of info on this set on here just type the model no. in on the search box.
  3. Kowkow
    Kowkow
    Only wondering, as various pictures show the 56 having a grey surround whilst the 56p has a black one..
  4. biggy7
    biggy7
    Jan 10, 2002
    2,549
    83
    Manchester
    +191
    anyone confirm that these are both the same model?
  5. OutKa5t
    OutKa5t
    Nov 30, 2005
    78
    I have the 32" 'p' version and my surround is grey. I can't find any differences between the 'p' and 'none p'
  6. dso
    dso
    Dec 19, 2005
    347
    28
    Manchester
    +24
    I have the 27WL56 and the buzzing only comes on if you hvae the 'Backlight' set at a high level - about 70%, or Picture mode 1.
    Selecting Picture Mode 3 gets rid of the buzzing as the backlight is at 30%. The picture is probably the best at this setting.
    The 32 version has got top reviews, so it would be a good buy, but if you try and stretch your budget to a Panasonic 32LXD52 that would be the best option:)
