Toshiba 32WL48P & Philips HDRW720/05 - small picture!
Discussion in 'LCD & LED LCD TVs' started by peskywinnets, May 25, 2005.
  1. peskywinnets
    peskywinnets
    May 8, 2005
    1,110
    48
    +60
    Apologies if this is the wrong forum, but having researched LCD TVs & HD recorders for my mum (she lives in the sticks *& doesn't receive digital nor wanted to shell out for Sky+!) I came up with the above combination....which she duly ordered.
    I live a few hundred miles away so she had to get someone local to install. I asked her watch she thought of her new setup & she said she's "a little disappointed". It turns out that when she use the Philips it doesn't fill the screen "just a small picture with space around the edges"...from what I can gather Philips HD recorder is attached to the TV via a scart.
    i reckon there has to be a setting somewhere on either the TV or the Philips HD recorder?
    Any top tips as to what could be happening here (I'm up there at the weekend).
    thanks,
    Pesky.
  2. benwong
    benwong
    I'll assume she's been recording 4:3 material on her recorder (to my knowledge, if she doesn't have sky digital or freeview etc, she won't be getting any 16x9 feeds apart from DVDs).
    She's watching 4:3 material on the 16x9 screen. The Tosh will either stretch the pic, zoom in, or display it at the correct ratio with black bars on the left and right of the picture.
    This probably explains the 'gaps round the edges'.
    Ben
  3. matt_p
    matt_p
    Apr 7, 2005
    845
    28
    Nottingham
    +38
    More likely is that the HD recorder is set to 4:3 letterbox? I assume the LCD is widescreen. That would give you a black border around the whole picture on a widescreen image.
    Check the recorder settings, make sure it is set to output 16:9 widescreen.
    matt
    EDIT: Sorry, I didn't read the model of the TV in the title. Of course it's widescreen! Pretty sure it's just the recorder set to 4:3 letterbox.
  4. benwong
    benwong
    That would be true when watching widescreen images from DVDs, Freeview, Sky Digital etc..
    Pesky,
    Is you mum watching movie DVDs, or is she watching stuff she's recorded off the TV?
    Ben
