Toshiba 32W8DB
K
kevin141
Hi, I have a Toshiba 32W8DB CRT TV. The problem is a red tint over the picture. As an X TV Engineer looked inside. There are no adjustments for the RGB CRT Guns. I suspect the Tube. Has anyone had a similar problem please.
Thanks kevin141.
It's a well-known problem with this and the 28in model...it is the crt.
They had a high failure rate...most of the crts fitted are Philips.
The RGB adjustments are done through software in the service menu.
Hi, Thanks for the reply. How do I get into the service menu?
Thanks,
Kev.
You can access the service menu depending on what uPC you have.
I think its the C7SS-Chassis in this model.
1. Press "Mute" on RC.
2. Press again and keep pressed while pressing "menu" key on control panel.
3. Release RC key.
4. Adjustment: Prog+/- = selection, Vol+/- = change values.
5. To store, switch off via RC.
6. Info: Use "AV" key to access internal test pictures.
or
1. Press MUTE key on RC and MENU on front panel while switching on.
Again sounds like your CRT is gone.
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
