Toshiba 32L4353 Reviewer's Recommended Best Settings
Discussion in 'LCD & LED LCD TVs Forum' started by hodg100, Aug 30, 2013.
Tags:
  1. hodg100
    hodg100
    Reviewer & News Writer
    Aug 8, 2005
    14,078
    3
    4
    +4,457
    Disclaimer: The settings below are supplied for information purposes only. We make no guarantee that using the adjustments below will improve your TV's picture, they may even make it look worse. Every TV, even from the same manufacturer and model number will vary, as will the environment the TV is used in. For further information on how to set up your TV, please follow the steps in our Picture Perfect campaign.
    To find a professional calibrator near you, see our Custom Installer and Calibrator Directory.
    You can read the review here: Toshiba 32L4353 review
    Column 1 Column 2
    0 Picture Mode:: Hollywood Day
    1 Backlight: 55
    2 Contrast: 89
    3 Colour: 0
    4 Tint: 0
    5 Sharpness: 0
    6 Advanced Picture Settings:
    7 Colour Master: Off
    8 Colour Temp: Warm
    9 Auto Brightness Sensor: Off
    10 Active Backlight Control: Off
    11 Black/White Level: Off
    12 Noise Reduction
    13 MPEG NR: Off
    14 DNR: Off
    15 Resolution +: Off
    16 Cinema Mode: On
    17 Expert Picture Settings:
    18 Window: Off
    19 Setting Type: 2P
    20 White Balance:
    21 Red-offset: 0
    22 Green-offset: -2
    23 Blue-Offset: -3
    24 Red-gain: 1
    25 Green-gain: -7
    26 Blue-gain: 7
