Toshiba 32 and aspect ratio
Discussion in 'Blu-ray & DVD Players & Recorders' started by davet010, Oct 21, 2004.
  1. davet010
    davet010
    Jul 23, 2004
    384
    +10
    I'm currently recording a series one Sky+, and having recorded 3 of them, set about editing them to fit them onto one DVD (using a bitrate of 4.2, the three have edited down to 41 mins each, so they will all fit).
    Only problem is that for some reason, when I try to insert chapters into the third episode to edit it, it says that it's in an aspect ratio of 4:3, compared to the 16:9 of the other two. This means that I can't put all 3 onto the same disk. I'm not sure how this came about.
    Thus far, I've tried..
    - using the machine's set up menu to force everything to 16:9
    - re-recording the show with the aspect ratio set as 16:9 in the timed record menu
    but neither have worked.
    Anyone any ideas, or am I doing something wrong ?
    I can re-record the show on Sky+ this Sunday, so if all else fails I'm going to try that, but I didn't change any settings between recording the second and the third shows, so don't know why they are different.
    cheers in advance
    DT
  2. davet010
    davet010
    Jul 23, 2004
    384
    +10
    anyone ?
  3. Dark Eyes
    Dark Eyes
    Jun 4, 2004
    124
    I cannot see why this should cause a problem.
    All my recordings are flagged as 4:3 (because I mainly use the internal tuner) even if they are 16:9.
    Then when I burn them to DVD I set the aspect ratio to 16:9 fixed in the Edit Menu options and they are flagged as 16:9 on playback.
    I did have a funny the other day, where I had edited the ads out of a prog and was then burning it to a disc, when I got the error message that the title contained incompatible material ( or something like that) and the the title would be divided when burnt to DVD. I carried on through the DVD burning menus and it all worked fine - no split titles and chapters as I was expecting.
    Might just be the software doing a 'funny' does it actually stop you burning the titles to DVD ?
    If so, are you making a -r or -rw and which method are you using ?
  4. davet010
    davet010
    Jul 23, 2004
    384
    +10
    Mixing the ratios will stop me burning them all to the same disk. It's completely baffled me as to why 2 of the three episodes are 16:9, and the other is 4:3.
  5. davet010
    davet010
    Jul 23, 2004
    384
    +10
    Sorted now - just forced them at 16:9 in the disk creation menu, as suggested. Quality is good - tried it on my Denon 500 !
