Toshiba (32/36)ZP48
Discussion in 'General TV Discussions Forum' started by Oakey, Sep 29, 2004.
  1. Oakey
    Oakey
    Aug 4, 2002
    537
    +6
    Looking to buy a Toshiba ZP48, do I go for the 32" or the 36" model?
    It's for a study, viewing distance will be about 6-7foot away.
    What's everyone's opinion on the Picture Frame 3? I know there were some porblems with PF1 and a lot of problems with PF2, and a few have had trouble with their PF3, but what's the general consensus? Is it worth the price and do the pro's outweigh the possibility of ending up with a dead TV?
    Also, I heard John Lewis are doing a 5 year warranty, is tis correct?
    thanks
  2. noikz
    noikz
    Sep 29, 2004
    562
    +23
    I'm in the same boat. I can't decide between the 32 and the 36. (or even whether to get a Toshiba or Panasonic).
    I've just called John Lewis regarding a "price match". They said they don't match with Sound and Vision or TV&V Direct. :(
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Without a shadow of a doubt I would recommend the 32ZP48. I have one and am absolutley delighted with every aspect of it (no pun intended). Nice looking, good sound, good picture. regards, yt.
