Toshiba 30WL46G LCD TV or 32" Hyundai ImageQuest
Discussion in 'LCD & LED LCD TVs Forum' started by Searcher73, Jun 22, 2005.
Tags:
  1. Searcher73
    Searcher73
    Jun 22, 2005
    215
    Can anyone give their recommendations on the following LCD TV's:
    Toshiba 30WL46G for £799 - ttp://www.play.com/play247.asp?source=484&page=title&Cur=257&r=ELEC&title=667864
    or
    32" Hyundai ImageQuest for £799 - http://www.cclonline.com/product-info.asp?id=3611#
    I am not concerned one is 30" and the other 32", I like the look of them both but unsure which one to go for, or if anyone can suggest something else for a similar price.
    Thanx
  2. CoolCurly
    CoolCurly
    Jun 10, 2005
    573
    46
    +104
    Go the distance and get the 32" Hyundai - you will not be disappointed!
  3. DanH
    DanH
    Feb 16, 2005
    604
    +56
    Ive not seen much on either of these LCDs, but the Hyundai hasnt got any digital connections listed in the spec. Although it states "Supports HD-TV", it appears as though this is through component connections only. If you are interested in buying a HD Ready TV, for use with future HD from Sky, HD-DVD, BluRay etc, this wont be enough.
    It also states a strange native resolution of "852 x 480 also supports 1024 x 768 with PC input". Im guessing it downscales the PC input to show on the 852x480 display maybe.
    Its the same case with the toshiba. Even though it has a DVI connection, it states on the toshiba website that it is not HDCP enabled. So again, if future High Definition content is important to you, look elsewhere.
    If your not interested in High Definition, then crack on. If you have no clue what im talking about with HDCP blah blah blah, then check out the FAQ at the top of this forum.
    But for something else for you to take a look at, the Samsung LE32R41B is around the £800 mark, and is fully HDTV compatible. Theres a large thread in this forum all about it too.
  4. bradavon78
    bradavon78
    May 31, 2004
    3,202
    South West, England
    +133
