Toshiba 30WL46, PC-DVI/AUDIO IN ???
Discussion in 'LCD & LED LCD TVs Forum' started by bossik, Dec 23, 2004.
Tags:
  1. bossik
    bossik
    Has anybody information about this type of input connector on the mentioned LCD TV? Is it digital? If yes, is it the same as S/PDIF?
    The connector by itself looks like 1/8" type.
    Thanx
  2. PhilB1234
    PhilB1234
    It's a plain and simple analogue input using a 3.5mm 'headphone' type jack. I'm currently using it on my set when I don't want to power up my processor and amps....
  3. bossik
    bossik
    Thanks, PhilB.
    I'll try as soon as I get a suitable cable.
  4. PhilB1234
    PhilB1234
    If you've got spare phono cables, the cheapest way is to just get a 2 phono > 3.5mm adaptor for about £2 from maplin or others....
  5. groovyf
    groovyf
    Jan 10, 2005
    78
    nm :E
    (sorry for bumping)
