Toshiba 28ZD26 Problem
JIimmy
I have had 2 Toshiba 28ZD26 with the same problem/fault with in 8 months. The problem is when I try and take the tv out of stanby it will either not come on for a few minutes, come on with no picture but sound, come on with picture and sound but I can turn chanels over. With all of these it then turns itself off ( back into standby mode ) all by itself.
The first Toshiba was a straight replacement for the one I currently have but this time they are sending an engineer out to see if he/she can fix it on site or in his/hers workshop.
Has anyone else experienced this problem with the tv or is it just a me that it has happened to twice :( .
JIimmy
If you are still under warrenty phone up toshiba/retailer and tell them the problem they should fix it or swap it. Thats what they did to me.
monkeynuts
Its out of warranty by about 6 months!
But have emailed them to see if it is a known fault as is easily repairable at one of their service centres.
JIimmy
It is not PAL progressive.
monkeynuts
Yep Jimmy's right.
Also...
Some owners feel it gives a better picture with porgressive scan mode selected for most viewing of non-progressive scan signals as it processes standard PAL singal better than sticking it on 100hz.....
Think this was discussed in depth at some point
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
