mobily
Hey all,
I have had the above television for a while now but for ages have had a problem with the component input. The coloured pins on the connection came off two of the connections and a while after this happened I experienced severe interference with diagonal lines down the screen when watching DVDs. I took the DVD player to the shop and they connected that to their television via component with no problem.
Either my component cable is the problem or the connection on the TV is gone which I think is more likely.
Has anyone else experienced this problem before? I find it frustrating as I am now watching DVDs via S-Video because the interference is so bad!
If so is there anything I can do to try and sort it out?
