Toshiba 28Z23B....
Discussion in 'General TV Discussions Forum' started by chegz60, Aug 11, 2002.
  1. chegz60
    chegz60
    Had the set a couple of days and unfortunately have to report a few BAD points.
    1. The geometry on the left side is very poor. Also convergence is not too great there either!
    2. The stand is CRAP! The small piece of grey painted chipboard directly supporting the set is bowing under the weight. (The pieces of glass sticking out are supported at the back only).
    3. The 5w rms/ch sound is really 'tinny'.
    It is such a pity as the picture is otherwise really good.
    I think I am going yo have to return it.
    Any other suggestions?:(
