Toshiba 28Z23B Going Back....
Discussion in 'General TV Discussions Forum' started by chegz60, Aug 12, 2002.
  1. chegz60
    chegz60
    So what next?
    Anyone recommend set under £600?:)
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,818
    71
    birkenhead
    +74
    why dont you try the 28zd26 mate you can get if from www.empiredirect.com for 640 i know its more than your budget.unless you have had enough of toshiba or something but by all accounts its a superb tv just have a look at the 32 inch thread
