Toshiba 28W8DB and the SD210
Discussion in 'Blu-ray & DVD Players & Recorders' started by zkat, Dec 30, 2001.
  1. zkat
    zkat
    Does anyone know if the 28W8DB takes component inputs, I can't off-hand ?
    I'm considering the SD210 to jump into the world of DVD, and reading thru the posts here on the quality of component input over others thought I'd check with people here before I buy !
    If it doesn't, should I still stick with the 210 (~GBP200 is my budget, considering it'll be my first player) ? As a minor point, the telly's black, so is the other kit under it.
    :confused:
    Cheers !
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    No it can't. About 18 months too old.
    Sure it can take RGB though. Use that.
