Toshiba 28 ZD 06 G any good????
Discussion in 'General TV Discussions Forum' started by gvr27, Oct 17, 2001.
  1. gvr27
    gvr27
    I'm about to buy a widescreen telly and I was originally going for an Pan 32PK25. But I've been reading about the problems everybody is having with this model.
    So it's time to look for another model. I've been admiring the Tosh 32ZD08 but I don't need the dolby sound. So I stumbled upon the 28ZD06.
    How about the picture quality?? Is it anywhere near the 32ZD08?? Does anyone have any significant problems with this set??
  2. Doubledoom
    Doubledoom
    The G on the end indicates that this is not a UK model but a European model (German i think).
  3. Damian1978
    Damian1978
    Jul 15, 2000
    4,519
    107
    Fleetwood, Lancashire
    +262
    Hi gvr27,
    Personally I don't rate the 28ZD06 very highly at all.
    Its a nice enough looking set but the pictures are ruined by a poor shadow mask (I think) as the edges of the picture look more pixellated than the centre. Every corner is out of focus, and vertical lines bow out at the edges and the colour balance between RGB and composite/tuner pictures has just shifted dramatically.
    You may be able to get a better example but I'm changing my rental to the new Panasonic TX28PL10 which looks fabulous after seeing my set!
    Hope this helps.....oh and sorry to bring bad news!
    :p
  4. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    Damian,
    Can you check if the PL10 suffers from the NTSC moire that afflicted the PK and PG series and has been often mentioned on this forum?
    Cheers,
    Grubert
  5. Damian1978
    Damian1978
    Jul 15, 2000
    4,519
    107
    +262
    Grubert,
    When the TV arrives on Monday I'll check out its NTSC performance.
    I hope its good.
