Northerner76
Established Member
Hi all
In my hunt for a native 1280by720 panel I stumbled across the Toshiba 27WLT56 - this a native 1280by720 screen with integrated freeview.
This screen should not be confused with the Toshib 27WL56P which is very different. Main differences between WLT56 and WL56P are:
Anyway, I am very close to buying this screen (available for around £470 to £550) and just wondered if people had any direct feedback on the TV with the 360...
In Theory the PQ for 360 should be top dollar as the screen does not scale the 720p output and FULLY supports 720p over component (needs component to VGA converter) or 1280by720 resolution if connected with MS VGA cable...
So any opinions?
- WLT has 1280by720 res
- WL has 1366by768 res
- WLT has no image processing
- WL has Toshiba Active Vision
- WLT has DVI and VGA
- WL has HDMI and VGA
So any opinions?
