Toshiba 27WL56 question
Discussion in 'LCD & LED LCD TVs Forum' started by kmm, Jun 14, 2005.
Tags:
  1. kmm
    kmm
    Jan 12, 2005
    3,621
    103
    +304
    Having just upgraded my 27WL46 to a 27WL56, I appear to be missing a function that the 46 had.
    It is the screen mode. With my 46 model, I could select Auto for screen mode and it would automatically select Wide or 4:3 depending on the signal it was receiving, however with the 56 model, scrolling through the screen mode options I cannot see an Auto mode.
    Does this mean (as I am curently doing) that I have to manually set Wide or 4:3 every time I change from a widescreen channel to a 4:3 channel ?
    I can't for the life of me imagine why Toshiba would take out a feature like this on a newer model TV. Maybe I have just missed it somewhere in a menu, but it is such a pain having to manually select the different modes all the time.
    Anyone know how to fix this ?
    Thanks,
    Kevin.
  2. AlpsUk
    AlpsUk
    Apr 3, 2005
    3,488
    Wellingborough
    +888
    I think the 27WL46 is a better model. It has more functions like picture in picture.
  3. kmm
    kmm
    Jan 12, 2005
    3,621
    103
    +304
    You know, I am beginning to think that myself now. Although the main reason I "upgraded" was for the 720p support, which the 46 doesn't have.
    Although saying that, I can't get 720p to work properly on my 56 (yet !)
    Would still like to get this screen mode selection sorted though
    Kevin.
  4. supermackem
    supermackem
    Feb 20, 2005
    2,150
    sunderland
    +78
    Is it not auto format on the Function screen mate. As for 720p i think this can only be used over hdmi as the vga just doesnt want to see it.
