Toshiba 27wl56 Hdtv Connection Probs
Discussion in 'LCD & LED LCD TVs' started by PROCESSOR69, Sep 5, 2005.
  1. PROCESSOR69
    PROCESSOR69
    Sep 5, 2005
    5
    :clap:
    HAVE GOT TOS LCD27WL56 I WANT TO CONNECT FROM PC CARD FX5200 WITH DVI OUT TO HDMI IN TO LCD27WL56 HAVE GOT LEAD BUT DOES NOT WORK ANY IDEAS!
  2. jesba
    jesba
    Mar 28, 2005
    23
    Well, the DVI-HDMI connection is not optimal, you can only use 720p and 1080i. I recommend you use a normal VGA cable and setup a 1366x768 res (or whatever the native res of that screen is).
  3. PROCESSOR69
    PROCESSOR69
    Sep 5, 2005
    5
    :lesson: I HAVE JUST PHONED TOSHIBA AND THEY SAY HDMI AND DVI ARE NOT COMPATABLE THAT CANT BE RIGHT ?
  4. jesba
    jesba
    Mar 28, 2005
    23
    That's BS. It is compatible and this is a fact. Though, if you're using a PC DVI output and connecting to HDMI input in your Toshiba, there might and will be some issues.
    I have the same set (except it's 32") and the picture through PC DVI-HDMI is bad. VGA input provides very nice picture, so I recommend you to use it, like I said in the previous post.
  5. PROCESSOR69
    PROCESSOR69
    Sep 5, 2005
    5
    Thanks for the info!
    I am abit peeved that dvi to hdmi lead cost £60.
  6. jesba
    jesba
    Mar 28, 2005
    23
    Yeah, I know. I paid a premium for my DVI-HDMI cable too, though I'm now using it with my DVD player so it was actually money well spent :cool:
  7. PROCESSOR69
    PROCESSOR69
    Sep 5, 2005
    5
    Trader Rating: (0) Toshiba 27wl56 Hdtv Connection Probs
    i want to use my vga as component from dvd player why does the DVI OUT TO hdmi not work?
  8. MADMAND
    MADMAND
    Aug 4, 2005
    343
    +8
