Toshiba 27WL46B
Discussion in 'TVs' started by finn1581, Sep 2, 2005.
  1. finn1581
    finn1581
    Just a word of warning to anyone buying a Toshiba 27wl46b
    Last christmas I brought the mentioned LCD TV from Currys and it was listed as being HD ready. (HDCP enabled)
    Now I found out that not only is it not HD ready, but It's not even capable of showing HD pictures as claimed by those nice people at Toshiba.
    I wish I was a bit more clued up at the time but as it was listed as being HD ready by Currys I was taken in.
    Now with a Xbox360 on order I may have to look at getting a new one.
    Does anybody know if any companies take trade in's. ??
  2. fave
    fave
    Feb 13, 2006
    11
    3
    you can use the Toshiba 27wl46b with the xbox 360 ( I do ) BUT you will need the VGA cable.
    No problems then
  3. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    I had the same set - got HD in via the vga input and mighty fine it looked to!
    Also managed to use the DVi input with an updated EID to get 1280 by 720 - excellent picture and watched numerous WMV clips from my PC....
