Toshiba 26WL46 and Hi-Def
Discussion in 'LCD & LED LCD TVs Forum' started by byron_hinson, Oct 23, 2004.
Tags:
  1. byron_hinson
    byron_hinson
    Aug 23, 2002
    1,743
    United Kingdom
    +247
    I'm just wondering what Hi-Definition modes the above TV supports, I can't find anything on the Toshiba site saying it.
  2. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    I have the 32WL46.....In the manual it states the sets will accept 720p and 1080i through the component inputs.....
  3. ianeby
    ianeby
    Nov 4, 2004
    3
    It seems that the TV does not have a DVI input but you can get HDTV when it comes out but through the componet inputs?
    What difference this makes we will have to wait until we can compare broadcasts using both inputs?
    I would think the difference will be negligable but it depends how much of a perfectionist you need to be, Oh! and how many devices you need to connect.
    I'm strongly considering buying one as you can get one for 899 pounds now. I think this is a bargain for the quality of lcd that it is although it is not completely future proof. But it today's world, tomorrows world is already history !!
