Toshiba 26" Widescreen Flat Tube HDTV: Is it any good???
E
Electrify
http://www.bestbuy.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0926INGFS10063717&catid=23239
I read a review for this TV (link at the bottom of page) which essentially calls this THE best looking HDTV you can buy, especially since we all know that CRT>>>All :smashin: . Anyways, one thing about it that troubles me is that it only displays in 540p/1080i. Since this thing upscales SD broadcasts and does not do full 720p, does this mean there is not much of a difference between SD or HD, or that HD looks significantly poorer than on a full 720p/480i capable set???
Review (larger model, assumed same quality): http://www.hometheatermag.com/crtdisplays/105toshiba/
Homepage (including manual, with resolution info): http://www.toshiba.ca/web/product.grp?lg=en&section=2&group=6&product=5312&category=
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
