Toshiba 24Z33 NTSC compatibility problems
Discussion in 'General TV Discussions Forum' started by Cactus_Chris, Jan 2, 2004.
  1. Cactus_Chris
    Cactus_Chris
    I just recently bought a brand new Toshiba 24Z33B from comet. The problem I am having is that whenever I play ntsc films via my DVD player or games via my Playstation 2 white lines that look like stretch marks appear on the right and left hand sides of the screen.
    They are really noticable in dark movies and are a real annoyance. Even when i play my ntsc japanese dremacast on the tv via an rgb scart cable the same problem occurs.
    This problem even occurs when i play my films and games using an rgb scart lead via the rgb scart port 1 on the tv.
    This problem does not occur at all with PAL material.
    Any help would be much appreciated.
    Regards
    Chris
  2. lardy
    lardy
    Jan 4, 2004
    96
    Coventry
  3. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    This problem (along with several others) is also being discussed more locally. :)
  4. Cactus_Chris
    Cactus_Chris
    Thanks for your help guys.
    I don't think i can try the s video option as the tv has no s video inputs do you guys have any other suggestions as i still cannot access that dvd forum that you posted the link to because my registration is taking forever to go through.
