Toshiba 23WLT
Discussion in 'LCD & LED LCD TVs Forum' started by john_p, Dec 9, 2004.
Tags:
  1. john_p
    john_p
    May 15, 2003
    70
    Have a problem with one of these .. it's got the integrated Freeview.
    Basically when switching into Freeview mode the picture freezes (usually static) and I can't access the menu. I can switch back into AV/analogue mode, but just can't do anything with Freeview.
    Could a low signal from the antenna cause this? Seems odd that it doesn't indicate "No signal received" as the manual states ..
  2. jon2099
    jon2099
    Jun 4, 2003
    183
    Hampshire
    +4
    Possibly, or it could be the RF cable is not adequately shielded (you need double-shielded RF cable) and is picking up noise. The noise can sometimes confuse the Freeview decoders and cause it to crash. My Philips (CRT) IDTV behaves in the same way- if I get too many glitches in the picture the Freeview part of the TV sometimes gets stuck i.e. cannot change channels, no MHEG-5, no EPG though most of the time the picture/sound still carries on as normal. I can still switch inputs, change to analogue, adjust picture settings, etc.
