Toshiba 21inchV33b2 geometry problem!
Discussion in 'Televisions' started by roorooroo, Dec 8, 2004.
  1. roorooroo
    roorooroo
    Dec 8, 2004
    361
    Cheshire
    +44
    Hello all
    I wonder if you could help me please.
    I have the above Toshiba set..the picture is great except that the lines on the four corners of the screen are spaced apart wider than the centre portion. This shows up as a really annoying problem ie: The four corners of the screen look like they are really low resolution compared to the rest of the screen.
    I think it is a geometry problem of some kind.
    I know how to access the first service menu page..but not the engineer and convergence pages..which I assume I will have to tinker with!
    Any help would be appreciated..it's driving me mad!
    Cheers all, Roo :smashin:
  2. roorooroo
    roorooroo
    Dec 8, 2004
    361
    Cheshire
    +44
    Mmm..i suppose it is a bit of a cheaper obscure TV set among all these expensive ones!
    Still no luck in attempting to cure the problem..does anyone have any ideas they could post?
    Cheers, Roo
