Toshiba 210e
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ricky27, Mar 12, 2002.
  1. Ricky27
    Ricky27
    Feb 8, 2002
    1,976
    Norwich
    +221
    I have been looking into upgrding my DVD and it seems that this model is about the best option.
    What are your opinions on this player please?
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Just buy it. It is head and shoulders better than the rest.
  3. Kevo
    Kevo
    Aug 23, 2001
    5,426
    Manchester
    +158
    Check that it can play CDRs, i'm not sure if it can.
    Also consider a DVD player with a second SCART for a loop through which is iseful for daisy chaining RGB devices,again I don't think the 210e has this.
  4. Doubledoom
    Doubledoom
    If you have component video inputs on your tv, then this player has component video outputs which means you don't have to worry about the scart.
  5. laurel
    laurel
    Ricky27
    It's a good player for the cash. Probably the best choice.
    You didn't mention your budget?? I assume it's sub £200.
    It will play CDR CDR/W no problem. It does not seem to be fussy with the media type either.
    Kevo is correct - there is only 1 scart, however whether this is a problem will depend on your situation.
    Laurel
  6. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    Ricky27, It's an accomplished player in it's price bracket.Some have reported the drive may be slightly noisey,but imo it compares well with the competition and it plays cdr's. Go buy and enjoy. :)
  7. Ron240
    Ron240
    Jan 3, 2002
    3,617
    Kirkcaldy (but i'm not a Fifer)
    +466
    An excellent player and excellent value for money.It can be a little noisey when spinning up but you only really notice this if you are sitting close to it.It also plays mp3's. Buy it!
  8. JOHN S
    JOHN S
    just a thought but what about the Pioneer 444 that the mags keep on about, I have seen it at £179 multiregion- @ upgradeheaven I think !
    JOHN S
  9. Ron240
    Ron240
    Jan 3, 2002
    3,617
    +466
    Wait.....! just heard about the new 220e.
  10. mancubas
    mancubas
    Jan 8, 2002
    514
    Derby
    +7
    Toshiba rolls out three new budget DVD players
    Hitting the streets soon are a trio of new DVD decks from industry stalwart Toshiba. Out in March are the SD-120E and SD-220E. The SD-120E is distinguished at its £160 price point by carrying component video outputs and an Enhanced Audio Mode offering three differents ways for improving audio playback.
    The £180 SD-220E adds to these features MP3 playback from CD-R discs and both optical AND coaxial digital audio outputs (the 120 only has coaxial). The SD-420E, meanwhile, adds a bit of design flare with a stylish half-mirror finish, as well as providing a built-in Dolby Digital 5.1 decoder.
    Posted by John Archer
    To link to this news item, bookmark this address : http://www.whatvideotv.com/news/fra...atvideotv.com/cgi-bin/displaynews.php?id=1598
