Toshiba 210E - Sound Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by GaryA, May 4, 2003.
  1. GaryA
    GaryA
    Jan 16, 2002
    14
    4
    While I was Watching a film on my Toshiba 210E, the sound just disappeared. When I turned the sound on my TV to maximum, I could just hear the film very faintly. I have checked all leads and they seem to be fine. I've also tried other DVD's.
    Has anybody out there any idea what the problem could be, and the solution if possible.
    Thanks.
    Gary
  2. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    How is your TV connected to the DVD player? I assume you are not using a separate amplifier or separate audio cables to connect to the TV?
  3. GaryA
    GaryA
    Jan 16, 2002
    14
    4
    It is connected to the TV using a scart lead.
  4. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    OK. Have you tried using a different SCART cable? If the picture is fine perhaps one of the audio connectors in the SCART has come loose. Or else the DVD player has just got faulty. Is it old? I have a Toshiba SD-220 that sound kept cutting out on to my amp. I found the reason to be that the coaxial digital cable connector on the back of the DVD player was dodgy, so I have to keep the cable angled slightly upwards for it to work!
  5. GaryA
    GaryA
    Jan 16, 2002
    14
    4
    I have tried other scart leads, with the same result. I have had the player for about 15 months (as usual just out of guarantee).
    Gary
  6. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    Since it happened in the middle of a film it has to be something just gone faulty at some stage - either DVD player, or TV. Perhaps try the player on a different TV. If sound works, then your TV's got a faulty SCART connector. If not, it's the DVD player. Good excuse to buy a new one I suppose!
  7. GaryA
    GaryA
    Jan 16, 2002
    14
    4
    Thanks for your help Sunil, I will try it on another TV.
    Gary
  8. hollie.weimeran
    hollie.weimeran
    I used to have an sd210 and had exactly the same problem - I was watching a DVD and the sound "popped" and just dissappeared, unfortunately its a fault that the 210e's are prone to. Mine was repaired under warranty - I don't think it was a particularly difficult fault to repair as it came back very quickly. Sorry I can't help with the technicalities.
  9. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    Same thing happened to my 210 a couple of months back - 2 weeks before the warranty expired. The guy in the shop said he's seen about a dozen or so with the same problem.
  10. GaryA
    GaryA
    Jan 16, 2002
    14
    4
    Thanks for the input. I am having it looked at in the next few days.
    Gary
