Toshiba 210e...Macro disable?
Discussion in 'Blu-ray & DVD Players & Recorders' started by damtom1, Feb 7, 2002.
  1. damtom1
    damtom1
    I,ve a Multi Region 210e.Can the Macro be disabled?If so how?
  2. Markster
    Markster
    u have 2 options with this player.
    Send it off and get it chipped by someone likely techtronics.com
    or
    Buy a macrovision remover scart cable www.sonel.com (approx £23 ish )
    My advice buy the scart cable, cheaper and easier
    HTH
