Toshiba 2109
Discussion in 'Blu-ray & DVD Players & Recorders' started by Momo, Aug 9, 2001.
  1. Momo
    Momo
    Can anybody out there help me with my player ?<br />I load a disc and it just keeps displaying the loading logo. When it does finally start playing after pressing the play button a few dozen times the picture is fine but then at random it just stutters and most of the screen turns into a mass of little blocks and the picture just hangs. The player is little used so is hardly worn out.Is the laser dirty ? Is the laser faulty.Would a laser cleaner do anything ?<br />Are there any cheap repair places out there ?<br />Any help appreciated
    Steve
  2. raigraphixs
    raigraphixs
    Jul 11, 2001
    63,041
    +23,908
    Try another disc, most probs like that are with dirty discs (clean it) or corrputed ones.
    rai
