Toshiba 2109 vs sd100
Discussion in 'Blu-ray & DVD Players & Recorders' started by Brox, Jul 5, 2002.
  1. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Does anyone know how these 2 machines compare, is the sd100 a cheaper version of the 2109 or is it a technically better machine?
  2. raigraphixs
    raigraphixs
    Jul 11, 2001
    60,402
    +22,054
    I know the 2109 is a excellent machine for its age, i brought my sister a 220E, and used components and svhs leads, and found it pretty much the same as my 2109.
    Toshiba make excellent players, just check for a review of both players on a website like www.homecinemachoice.com, etc
    rai
  3. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    The SD100 was brought out to replace the 2109, and supposedly improves on it. It's definitely not a cheaper version of the latter. I haven't done a side-by-side comparison of the 2 machines, but I can tell you that the SD100 gives absolutely superb picture quality on my Tosh RPTV.
