Toshiba 210 - quick review
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jase, Jul 11, 2001.
  1. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    Hi Guys & Gals
    Just got myself a Toshiba 210e as a stop gap before i get an upmarket player.
    It has to be said the playback is superb, certainly better than my Panasonic a360, its also way better than the Panny for cd playback as well.
    As for the supposed noisy drive, you can hardly hear it, you´d have to stick your head right next to it when watching a film needless to say i wont be doing that!!
    Layer changes are ok , about the same as the Panny, there are zoom features etc but i dont use them so for me they´re a non issue.
    Overall i´m pretty impressed by it. Well recommended for the money.
    Jase
  2. MikeD
    MikeD
    Mar 17, 2001
    265
    Paignton, Devon, UK
    I'm with you on all you said Hooty but just to add my little bit I find the zoom excellent. To get the best out of my projector with 1:2.35 aspect ratio DVD's, I always use the first zoom level which utilises more of the DLP panels height without cutting off much of the picture at either end and with no apparent loss in picture quality. Even at the second level of zoom the quality appears to be just as good.
    Cheers MikeD
