Toshiba 19DV555DB DVD Problem - Advice Please
chris301up
My Wife has a Toshiba 19DV555DB TV/DVD which as developed a fault. Initially the DVD stopped working and, believing the fault to be with the DVD player itself, I managed to locate a replacement which I have now installed. Although the DVD will now work it only will play for a few minutes then stop and we then get the message 'incorrect disc' displayed on screen. If switch the TV off at the mains, let it cool down for a while, and then switch it back on it will work for a short time and then the problem repeats itself.
As anyone had a similar issue and know where the fault may lie?
RBZ5416
I would suggest that you've replaced a faulty drive with a slightly less faulty drive.
