Just got one of these from Argos and couldn't get some of the channels to tune in so run it through freeview box used for previous tv no problems
An arial booster solved the problem and telly works as it should without the external box
However now keeps coming up with error messgae common module interface removed- telly is new and have never used this port for anything.
Toshiba said try resetting to 1st time install which I have done but still have same problem take it back to shop- problem is I have thrown the box away
I thought I would try on here before I try anyway
