Toshib 36zp18p Default Settings Please
Discussion in 'General TV Discussions Forum' started by bjd, Feb 6, 2002.
  1. bjd
    bjd
    Feb 4, 2002
    2,770
    N. Ireland
    +711
    Could any 36zp18 owner please check their default values for CNR, PARA, and Trap in the Service Menu........I may have messed mine up. :)
  2. HBK757
    HBK757
    Jan 15, 2002
    153
    16
    Can't help with the default settings, but this is why its so important to write down service menu defaults before changing ANYTHING ! It's too damn easy to mess your tv up :mad: :mad: :mad: Good luck, I hope you find them :D
  3. bjd
    bjd
    Feb 4, 2002
    2,770
    N. Ireland
    +711
    I DID write them down.......unfortunately, I forgot to tell my daughter that the piece of paper wasn't just scribbles, so she binned it. Maybe someone could even give me settings for those parameters that they use :)
  4. Doubledoom
    Doubledoom
    Which zoom mode do you want them for (they are not universal throughout the modes)
    Is yours a B or G model (service mode values differ)?
  5. bjd
    bjd
    Feb 4, 2002
    2,770
    N. Ireland
    +711
    It's a G model........and just the widescreen 16:9 will do, thanks
  6. Doubledoom
    Doubledoom
    Can't help you there then. However, now we know you are after the Wide mode settings and you have a 36ZP18P (G), you should get some answers (hopefully....)
  7. naim
    naim
    Sep 28, 2001
    140
    up north
    CNR 18H
    PARA 08H
    TRAP 4EH
    These are the settings of 2 different peoples TVs
    check you may have to tinker a bit to adjust for your own taste
    the above settings are right :cool: :rolleyes:
  8. bjd
    bjd
    Feb 4, 2002
    2,770
    N. Ireland
    +711
    Thanks a lot naim. It turns out that those values are very close to what I had it adjusted to. I suppose the geometry on this set is just another bonus feature, as I, for one, can't get it anywhere near as good as it should be. still, it's only really noticeable if watching tennis or something else with vertical lines......I still love this TV :)
