Tosh32 - sound problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by chumley, Sep 17, 2004.
  1. chumley
    chumley
    Yet another problem (is it me?)
    Recorded Indiana Jones (for the wife ofcourse) last night to HDD and started to watch it tonight. The sountrack is all over the place - the music very loud and the dialogue barely audible. Investigating further, if I switch between straight TV broadcast and DVR (using AV button) the TV sound is far superior i.e clearer dialogue and generally louder. Tried reading the manual but got totally confused with the audio stuff.
    Can anyone suggest why the DVR sounds so bad - thanks.
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    It sounds as if you have the sound output set to a custom mode of some sort - e.g. Surround sound or Bitstream......
    So if you have changed anything (possibly inadvertantly) it may be an idea to restore the machine's default settings.
  3. chiastic
    chiastic
    Sep 14, 2004
    5
    I noticed that when watching it on the TV the sound levels wee so badly defined between the voice, background noises, and the music that I had to completely re-level my TV speakers.
    That might be the problem.
  4. chumley
    chumley
    I don't suppose you know how to do this with the Tosh do you - can't find it in the manual?
  5. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I've looked throught the downloaded manuals and can't find anything on restoring to default settings either.
    I assume your problem is with the sound through your TV and not through a hi-fi system connected to the audio out sockets.
    Have a look at page 48 of the Installation Guide. and try these settings:
    Audio Out = Analog 2ch (should only affect connected hi-fi)
    Virtual Surround = Off
    Nicam = On
    Have you noticed the same problem on other recordings?
