Tosh XS32 RF output?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dabs09, Dec 10, 2004.
  1. Dabs09
    Dabs09
    Anyone know how to set up a Tosh XS32 to output through the RF lead? I'm trying to hook up to other TV's in bedrooms etc. :lease:
  2. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    Hi Dabs,
    I think we've already answered this for you in the thread "RF output from Toshiba rd-xs32" in the DVD Players forum. The Tosh doesn't output an RF signal, just loops-thru.
    However, you could split your incoming RF signal via a splitter, then put one feed in the Tosh and the other feed into the device you use to send an RF signal to your other TV sets.
  3. Dabs09
    Dabs09
    Its not the incoming RF signal that I am after, thats OK. Its the output from the Tosh itself that I want to distribute.
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    No, the XS32 can't do this (and I don't believe this is unique to the XS32). See page 15 of the installation manual. "Watching via the RF OUT terminal is not available".
    Mark
  5. Dabs09
    Dabs09
    Is there any other way to get an output from the tosh into an rf lead - any converters from a scart output for instance?
  6. SDHoward
    SDHoward
    Nov 1, 2004
    250
    If you already have a video recorder you could use that by setting it to look at a scart input from the toshiba recorder (which is what I do).. otherwise something like this http://www.satcure.co.uk/accs/page4.htm should do the job.
  7. Dabs09
    Dabs09
    Tried the video recorder idea and it works fine, once I remembered to to set the video in tuner mode. Thanks for that suggestion
